setback thermostsats f steam systems
gerry gill
Member Posts: 3,078
how well the system has been maintained..they will work just fine if the pipes are insulated, boilers not to big, if the firing rate matches the load, if the air vents work well, if the traps work well..in short, if its a well maintained system..if not....hammer noise time..
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=360&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
gwgillplumbingandheating.com
Setback Thermostats/Steam Systems
setback thermostats for steam systems?good or bad idea?0 -
Also, probably won't save any fuel/money if the house is all masonry - high mass.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
