Steam Pressure Gauge
mike jones
Member Posts: 32
http://www.gaugestore.com/98wikgaug05p1.html
Does anyone know where one can find a pressure gauge for a one-pipe steam system?0 -
Any supply house
should carry them.
Grainger, or anybody. 15 psi, on top somewhere, don't forget the pigtail, big dial and #'s, in case I have to read it. Good luck0 -
That gauge at the gage store is rated for only 140 deg F. Is that good enough for steam?0 -
140 degree
Being mounted on a pigtail steam never reaches the diaphragm
HitzKup0 -
Thats true, but if it.s coming right out of the top of the boiler it could still get up there, although I've never seen one fail right off. Good luck.0 -
low pressure gauge for 1 pipe steam boiler to register
I dug out that link: http://www.gaugestore.com/98wikgaug05p1.html
searching for our own zero - five to replace our pressure guage, so I can't recommend it cause we havn't bought it yet. Does this even have a prayer of working given all these limitations 140 degrees, pigtail, top of boiler,etc. Unfortunately, with all our research we can't find anyone else that even carries 0-5, at least not in NY, which is a small market. They torture steam people don't they? When we blow through our 0-15, it registers to 2, so if our boiler is overactive which we expect, it could at least show us the 2, shouldn't it ? ps. I read somewhere I cant now find in another link there is a TYPE of gauge we should get, some fancy word like (pneumatic, though thats probably not even close to the real word)
Mike, you need to be aware
of Code requirements for steam gauges.
The ASME Code (which has been made law in many locations) states that a gauge on a steam boiler shall be capable of indicating twice the boiler's maximum working pressure. Since residential steam boilers usually have a maximum working pressure of 15 pounds (even though the SYSTEMS they're connected to should not go over 2 pounds) this means that the gauge must read to 30 pounds.
This does not mean you can't install a 0-5 pound gauge, but you must also have a 0-30 pound gauge in place to meet Code.
I've been following this thread because I want to add a second gauge too. So if I want to use 2 gauges, 0-30 and 0-5, is the 0-5 wika a good one to use? That is, will it hold up well on a steam boiler?0 -
Geez Louise you guys are working too hard, a single 30 PSI will do fine, a 15 will work too, your blow off probably goes off at 15!! If you want accuracy and longevity get a liquid filled one for a few extra bucks. Take a break!!!0 -
Bet
you've never had an inspector make an issue of that.
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
