Steam Heat problems
HitzKup_2
Member Posts: 45
try find a profesional far left top
Steam Heat Problems
I've been having a problem since Sunday, where everytime the heat kicks on - the one radiator in my bedroom spits out water through the little valve where usually only steam should come out.
My husband is away on business and I'm stuck trying to solve this mystery. He says to flush the water in the system a few times b/c this could happen when the water is dirty. So, I spent 3 hours last night emptying & filling & emptying & filling the water - until it started to come out somewhat clear. This morning, when the heat kicked back on - I still had the same problem where it makes a gurgling sound and spits out water.
Please help if you know the answer. I'm going nuts!
Thanks,
Jennifer0 -
spitting problem
When your boiler water is dirty rising steam and/or surging water lifts the crud into the radiator and may clog the air vent preventing it from closing.
Remove the offending vent and place it in a heated vinegar solution to soak for a while (this may loosen the mineral, rust and dirt deposits which prevent the vent from closing). Better yet, buy an new vent. Don't buy the cheap ones ($4) at the local big box store. Go to a plumbing supply store and pick up an adjustable vent ($15 approx. hoffman,dole or ventrite).
Finally, when you flushed the boiler, did you refill only to the halfway point in the sight glass? If so, fine, if not, drain the boiler until the water is halfway up the sight glass. (I used to put it 3/4 up in past and this caused surging and spitting in the closest radiator to the boiler.)
Dan
PS: Is the radiator steam input valve fully open?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
