indirect for radiant
hr
Member Posts: 6,106
be in there for a separation of non barrier tube from the boiler. Basically an indirect is just a heat exchanger.
They are often used in systems that have very small "micro" zones to help ease boiler cycling.
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
hot rod
indirect
Is there any big advantage to using a indirect off of a boiler to feed several zones of radiant. I saw an instalation today with two superstores side by side one for domestic hw and one for 4 zones of radiant. My boss says that this is done all the time to boost capacity and to cut back on boiler cycling..looks like a lot of extra hardware to me..any thoughts?0 -
Sounds like one is used as a buffer tank. It adds mass to the system and reduces short cycling of a oversized boiler or a boiler short cycling on a warm day.
TimJust a guy running some pipes.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
