Towel warmers
Brad White_9
Member Posts: 2,440
six gallons, which serves the need for my radiant floor off season. This was piped in parallel with the "in season" gas fired boiler.
Hot Rod had something similar concocted as a package complete with E-Tank, circulator and controls.
Mine was cobbled together and only had an on-off switch and the tank thermostat. Worked well enough but could have been more sophisticated in control to provide less operating cost.
Controling towel warmers
I have used timers, thermostats, switches etc.
All have their short comings.
Also what about using then in the summer, when the boiler is shut down with WWSD.
Someone suggested the other day to connect them to the dhw priority zone which operates in the summer.
I also thout of using a set point controller with a Tekmar 363 controler.
All suggestions welcome
Rich Swatton
Authorized Heat Tranfer Products Sevice Agent0 -
Got room for
an electric towel bar on another wall/ probably the simplest least expensive. or as Brad mentioned put a small electric heat in the hydronic circuit. Laing makes a nice combo heater/ pump 2 KW.
Here is the Laing with a couple ZVs for two small bathroom floor zones.
hot rod
Got room for
hot rod
Got room for
an electric towel bar on another wall? Probably the simplest least expensive. Or as Brad mentioned put a small electric heat in the hydronic circuit. Laing makes a nice combo heater/ pump 2 KW.
I post pic later.
hot rod
Got room for
I post pic later.
hot rod
I have done the loop of the DHW thing. It works well. I used a Taco 2 zone controller and just wired the end switch to the DHW priority. I generally put towel warmers on a timer switch or a programmable timer switch. Here is how I piped it...
temperatures
I like the idea of using a 6 gallon DHWH for a summertime application or maybe year round.
Which brings me to the next question.
At what temperatures do you run your towel warmers?
I have always mixed them down to 140* with a fixed temp mixing valve and progresive re-set.
I just think that 180* running for without out door re- set will over heat the room or be dangerous for little fingers.
Rich
Temperatures
Rich,
I set the DHW aquatstat for about 120, that is just a preference. I could get 160 out of it when at full tilt but that was too much for the space. (No AC, just exhaust via a heat exchanger).
I imagine I could use a TRV responding to space or to surface temperature but what I have is simple enough, adjusted at the DHW heater. Again, jury-rigged and left that way; not thoroughly thought out.0
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
