Winter Love ( for wetheads)
American Plumber_2
Member Posts: 2
I think it stays around 70 year round, more or less.
wow...looks...
very nice...quite the upgrade...the only part that I question is the barometric draft control...kpc
may i ask a question ?
with all the insulation on the pipe...what is the boiler room ambient air temp in Late January?0 -
Real Nice
Love that Silver and Orange stuff! I'm curious as to how well that flue muffler works. I have a couple installs that due to room acoustics and the location, the burner noise is quite loud and I considering recommending a muff to the customers. Don't want to tell them to buy something that delivers marginal performance.0 -
Vito go!
wow, you think there is an improvement? Nice job. All that silver and orange bling.
silencer
On this particular job,the owner did not ask about AFUE ratings,boiler brands or the expected longevity of the new system. Her only question was " will it be quiet ? " The silencer cuts down on the high frequecy sound fairly well (50%?) especially when using the riello burner.You will still hear the lower rumble of combustion,but overall you can expect a much quieter system.Check to be sure that the silencer will fit without major boiler repiping.I buy my units from Viessman but Selkirk makes a more compact unit if the situation requires.To cut down on sound further you should seal all joints with Hi-Temp silicone and insulate all vent piping.Another option if you do not have the space for a silencer is to fit the boiler with a Beckett NX burner,I find them to be resonably quiet. Good Luck.0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
