Sizing radiant system in remodel
Al Letellier_9
Member Posts: 929
Paul, every structure is different and the heat required will vary with construction and all the details you mentioned. You need to find a heating pro, an engineer or a consultant to do a proper heat loss on YOUR building. Rules of thumb don't apply when doing the job correctly. After the load is determined, you can look into options for your boiler, but a water heater is a water heater, and life expenctancy is far less than a boiler.....and local codes may dictate what you can and can't do.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=248&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
System sizing
I'm doing a remodel and I'm adding 1000 sq. ft of heating space to my 600 sq. ft. I currently have. My current system is a radiant slab powered by a 40 gal dedicated water heater. The additional 1000 ft. will also be radiant. How do I calculate the amount of btu's I need to heat my new project. Should I consider a electric boiler over the water heater. (We dont have gas or propane) My cabin is at 8700ft in elevation with lots of south facing glazing.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
