Hot / Cold Fluctuations
Gene_2
Member Posts: 59
Plumbing issue: I maintain a resort which includes a building that is well over 100 years old and has the problem of when one shower is in use, the other shower loses pressure and hot water. It doesn't seem to be affected by a flushing toilet. Ideas on how to remedy? By the way, thanks to Rocky for the advice on the in-floor heat knocking issue.
Pressure Balancing Shower Valves
Spend the bucks.
Jed0 -
what is the
Pressure in the building? are the pipes properly sized? and is this happenening all over?? but I would agree that pressure balancing shower bodies would help, but if your running 40 pounds psi, you might still lose hot water as there is a pressure drop through the coil or hot water heater. if you are running very low water pressures, then maybe a skid mounted pressure booster system might work well, these are a few ideas to look into. but have a reputable plumber come in and check0 -
there is a retrofit balancing valve
that can be put in-line without pulling out the shower valves. The other blogs pretty well say it all0 -
think we need more info..
are the showers in question back to back? what is the water piping made of? 100 years old, is it steel? what do you mean by pressure loss? just hot water? cold too? losing pressure in shower B, when shower A is running sounds like a possible occluded pipe....just a thought..oh, the others are correct in their desire for pressure balance and or thermostatic valves...but being a resort i'd hope they are already in.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"gwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
