Mixed Water Temperatures at a TEE
Michal
Member Posts: 213
Thanks for the share, Dan, covered this last night in his seminar, Thats Wonderful
Mixed Temperatures at a TEE
I recently read the artical in RPA about calculating mixed temperature at a TEE. I have had a program that I made for doing this in microsoft excel for some time now. I'd like any of you who are interested to have a copy. This can sve you a little math, in case you don't want to go back to school just to get a mix calculation.0 -
Dear Ubi
THAT'S SWEET!!!!!!!!!
Now can you fab up a file that will do the same thing for a Low Loss Header type application?0 -
add the 2, and divid by 2
That is really neat. if you on the job, and need to know what the mix temperature is try adding the two temperatures, and divide by 2 you will get the same mix temperature everytime.
Taco, Inc.
Joe Mattiello
Technical Service Technician
joemat@taco-hvac.com
401-942-8000 X 484
www.taco-hvac.comJoe Mattiello
Taco Comfort Solutions0 -
THIS
Is what makes the Wall .. SO COOL ....
Great stuff and Thanks for sharing.
Scott
What?
Only if the two flows are the same.
Are you having a bad day, Joe?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
