Load Calc Software
John_87
Member Posts: 1
I'm trying to find a good load calc program and wanted to see what other people are using and how they like it. Also if anybody has a good dispatching program that info would be greatly appreciated.
oops double post
I have 3
For general heat loss calcs, I use the free slant-fin software on small baseboard remodel jobs, or when I am just double checking my main software- Wrightsoft. I love my Wrightsoft program, I can quickly draw a building into the cad program, draw windows, doors, and describe the building levels and it will take care of Manual-J calcs for me with everything I need including Radiant, and A/C. It is however a little pricey, and there was definitely a learning curve for me anyway.
I also have the Wirsbo (oops, Uponor) ADS software I use on every big radiant job.
Cosmo Valavanis
Dependable P.H.C. Inc.0 -
You could also consider
... HVAC-Calc, a fairly complete heat-loss and gain program if the majority of your work has to do with air-based systems. While it's only Manual-J, 7th ed., it should do the trick for most people. For a more comprehensive review, check out my review in on the Job section.0 -
wrightsoft 6.0
Hey Cosmo,
Have you seen the latest verion 6.0????
Cooooooooooooooooooooooool!
wheels0 -
What do you think
I got the email from Wrightsoft, and I did'nt hesitate for a couple bucks it cost. I would like to spend some time fooling around with it to see all the new stuff, but when I need to use it I am usually in a hurry. Hey I just talked to heatboy today....when are we gonna get together for some beer and dinner dude
Cosmo Valavanis
I use Wrightsoft for heat loads, radiant, and A/C. I have tried HVAC-Calc and it always "feels" way to light on the A/C end. Baseboard calcs are good, but not A/C. When you call HVAC-Calc for support, it is very difficult to get answers. Don is not much of a people person. When you call Wrightsoft you get great support....0 -
Can Wrightsoft figure loads when using icynene or how can you compensate for it?0 -
Interesting question...
... I have not used Wrightsoft, but since the only thermal difference between Icynene and FG is the infiltration/convection rate, I'd like to think that using an equivalent FG thickness would be fairly close to the mark, if a bit conservative.
In HVAC-Calc, you can adjust the infiltration rate of the home manually. Presumably, the same thing can be done with Wrightsoft.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
