tekmar Boiler Control 263 now available
DaveGateway
Member Posts: 568
the long awaited Perrless Pinnacle boiler control solution we've been waiting for?
tekmar 263 now available
I've had a few questions as to when the Boiler Control 263 will be available. It has been available as of September 1, 2004.
The tekmar Boiler Control 263 can operate either two on-off boilers or a single modulating boiler. It provides outdoor reset with optional indoor feedback plus domestic hot water pump or valve logic with priority. It also has an internal setback timer built-in.
The Boiler Control 263 and the 265 can connect to any modulating boiler that supports a 4-20 mA, 0-10 Vdc, or a 0-135 Ohm analog signal that adjusts the boilers firing rate. Some boilers require a optional converter in order to do this.
The Data Brochure can be found here:
www.tekmarcontrols.com/acrobat/d263.pdf
and the Application Brochure here:
www.tekmarcontrols.com/acrobat/a263.pdf
Any questions can answers by calling us at tekmar.
Jay www.tekmarcontrols.com 1-250-545-77490 -
Compatible with Peerless Pinnacle
The tekmar 263 can operate with the Peerless Pinnacle that has the new P125 control board. I believe the 263 is not compatible with the previous control board in the Pinnacle. Please consult with Peerless to verify this.
Jay0 -
Looking forward to the 263 in my stock
I did bid a job to a contractor that the 263 would be perfect for, but I am using a 265 instead since my 263's haven't hit the dock yet. This is what my contractor has ahead of him next week when he starts piping.
(Taco pump sales are through the roof this month.)
This is an 8000 sqft residence with a 1000 sqft storage area and 1200 sqft garage + DHW. Biggest residential job to date. I will post actual pictures as my plumbercraftsman progress'.
Regards,
PR0 -
Does this work with the munchkin line?
I've heard rumor of an adaptor that allows the munchkin boilers (for example the m140) to work with this, but I haven't been able to find anyone that actually has it. Anyone know any more specifics, and hopefully an HTP part number?0 -
Question....?
Is this home using radiant heat throughout? Does each pump control a manifold or perhaps radiator zones?
each pump is controlling
its own radiant floor heat zone. All 12 zones are SOG, low temp radiant.
regards,
PR0 -
Graphics
Wow, the graghics in your attachments look awsome. What program are you using and how long does it take to put together.
Thanks Jim0 -
Sell more Tekmar 263s
Jay, I understand your reluctance to speak for Peerless, but rather than lots contractors trying to get some answers from up the supply chain, could you work with Peerless to find out more about the P125 board and its interoperability with the 263. Many current Pinnacle installations may be begging for outdoor reset modulation, so if you can get a definitive answer on the backward compatibity of the P125 board that would be very helpful too.0 -
Please call Peerless
Please call Peerless or a Peerless manufacturers rep on information about the Pinnacle line.
Jay0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
