Looking for outdoor boiler for baseboard hot water
David Oleynik
Member Posts: 1
I am looking to replace an existing outdoor oil fired boiler for a central Vermont ski house, with either an oil or gas fired outdoor boiler. Can anyone recommend a dealer or manufacturer of this type of unit?
There are a few boiler makers
that have outdoor versions of their equipment, but I would look into putting a unit indoors since you'll experience so much heat loss with the unit outdoors. You have balance flue oil fired that can be side wall vented and high efficency gas boilers that can be vented with PVC piping.
A wall bung gas condensing boiler could fit nicely in a closet. If you must stay outside, consider building a shed for extra protection from the elements.0 -
Why
outside?
Sometimes snowmelt boilers are located outdoors, most copper tube boilers have outdoor kits available.
Patterson Kelly makes larger sized condensors, I believe, for outdoor use.
hot rod
I know these boilers aren't gas or oil fired, but you might want to check them out.
http://www.FreeHeatMachine.com/0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
