Cleaning out steam vents
Kevin_23
Member Posts: 8
that they boiled their steam vents in a vinegar/water solution?
What do the pros think? Can this be done? I've already replaced all 13 of my steam vents and want to put an end to the $16/vent madness ($75 for the main)!
> What do the pros
Sure you can
I'm not a pro, but I've heard from pros that you can. I've done it successfully with a few of my vents and it worked fine. The mild acidity of the vinegar helps dissolve away deposits. Of course, there is a chance your vent is just plain broken, too. You'll need to test it once you've cleaned it.
If they've all broken, however, perhaps that signifies a deeper problem.
-Michael
Kevin
You could also try to use some0 -
Thanks guys, my oldest vent is 3 years old. My steam main vent started hissing after being 5 months old. I lightly tap with a wrench on the pipe just below the main vent, and the hissing immediately stops. I think there is a piece of sediment in it.
I was considering boiling the main vent, along with 5 or 6 of my radiator vents to see if they would hiss less (or not at all). I have cleaned my system out quite a bit this winter and feel there has been some sediment find its way to the vents.
Thanks for the responses!0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
