Cleaning out steam vents
Kevin_23
Kevin_23 Member Posts: 8
that they boiled their steam vents in a vinegar/water solution?
What do the pros think? Can this be done? I've already replaced all 13 of my steam vents and want to put an end to the $16/vent madness ($75 for the main)!
  • michael_15
    michael_15 Member Posts: 231
    > What do the pros
  • michael_15
    Sure you can
    I'm not a pro, but I've heard from pros that you can. I've done it successfully with a few of my vents and it worked fine. The mild acidity of the vinegar helps dissolve away deposits. Of course, there is a chance your vent is just plain broken, too. You'll need to test it once you've cleaned it.
    If they've all broken, however, perhaps that signifies a deeper problem.
    -Michael
  • jesse the great
    jesse the great Member Posts: 72
    Kevin
    You could also try to use some
  • Kevin_23
    Thanks guys, my oldest vent is 3 years old. My steam main vent started hissing after being 5 months old. I lightly tap with a wrench on the pipe just below the main vent, and the hissing immediately stops. I think there is a piece of sediment in it.
    I was considering boiling the main vent, along with 5 or 6 of my radiator vents to see if they would hiss less (or not at all). I have cleaned my system out quite a bit this winter and feel there has been some sediment find its way to the vents.
    Thanks for the responses!
