Buffer tanks ?
Jim Miller_2
Member Posts: 9
what are you all using for buffer tanks on radiant jobs?
I am planning to use a Munch T80 and a superstor, but the SSU won't work for buffer the way I see it.....
thanks
thanks
HTP Buffer
HTP makes a SSU buffer tank. It has 4 - 1 1/4" tappings and a tapping on the top for a vent. It comes in various sizes. Give them a call they are very helpful.
reverse indirects
Just get an indirect that has the DHW in the coil and the tank filled with boiler water. BEcomes your buffer and hot water source. Just need an anti-scalding valve on the hot water supply. Checkout www.ergomax.com, www.thermo2000.com, dunkirk artesian, Laars duraflow, www.tfi-everhot.com0 -
Pretty much
all the water heater manufactures offer blank insulated tanks, if you don't need a HX coil this is the least expensive insulated tank.
Lochinvar now offers tanks the 2" foamed RVU models, in the 120, 200, 300, and 500 gallon size (ASME) with plenty of taps for buffer applications.
I have used electric water heaters, as they are readily available, and inexpensive. The element holes 1" NPT can be used for additional connections.
hot rod
thanks for all the input - I did not think about using the element holes for piping!0 -
Yeah!
use electric water heaters all the time. I've been curious about the Dunkirk Artesian indirect though. Has anybody used one yet??? WW
piping the water heater as buffer
- should it be opposite of what I would pipe it as water heater - what I mean - do I want to draw the coldest water out of it (bottom) to send back to the boiler so that the Munch will operate at cooler temp or will the colder water cause the controller to ramp up the firing rate or how does that work?0 -
I would say
that putting the buffer on the return so the condensor sees the cooler temperature make sense. Think I recall seeing some tekmar piping schematics drawn the way.
I have a local supplier that carries 1" male by 1-1/4" copper adapters. This allows for some larger flows when you use the element ports.
I use a hole saw to place a neat hole in the element service cover.
If you use glycol or other inhibitor chemicals, I'd recommend removing the anode rod. Unless you use Rhomar or other "all metal" friendly chemicals. In a closed loop application the anode isn't all that necessary, IMO.
hot rod
buffer drawing & pic.
This is an old job we did about 2 to 3 yrs ago. Working great. The system has a Tekmar 361. The boiler sensor is in the buffer. The slab is about 15,000btu.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
