rigid pro press
MT
MT Member Posts: 21
hey guys can anyone here tell me how the pro press is. Sounds awesome, I saw it at a show in atlantic city talk to the rep about it. I personaly think everybody will be using it, but I wanted to know anybody using it and how do they like it? using it for residential?
  • MT
    MT Member Posts: 21
    buderus
    I am thinking of installing a buderus boiler for a customer of mine and wanted to install a power vent, I never used a power vent before! My customer wants to place it in the garage on the back wall. Can I run the flue to the left hand wall and out the house. The reason for this is because there are decks on the other side of back wall. little help?
  • S Davis
    S Davis Member Posts: 491
    ProPress
    We got ours about four months ago and never looked back, I can pipe a boiler pannle that used to take three days in about one day give or take, the one thing is making sure your parts house will carry enough fittings, we ended up buying a pretty large stock of fittings because nothing looks worse than having ProPress and solderd fittings on the same boiler pannle, it workes really well, but takes a little time getting used to how it will pull the pipe toward the tool when you make a crimp, to counter this on the larger fittings you need to press one side of the fitting and then turn the fitting around to press the other end of the fitting.
    S Davis
    Apex Radiant Heating
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    Gotta love this tool!
    The shiniest example of its use began today with my first freeze up of the year. No sitting around waiting for the water to stop flowing, while waiting to solder a joint. Cut out the puckered piece, a couple of slip couplings, press X 4 and purge it out. In/out WAY quicker than the old method and on your way to the next money making job.(how much do you make on slip couplings ? Time is of the essence) Chris
  • John Felciano
    John Felciano Member Posts: 411
    propress
    Is one of the best investments I've ever made.Been useing it for a year now and love it.Fitting availabilty which had been a problem is no longer a problem with more and more suppliers now stocking fittings.We use pex for water piping and loops so we're mostly using it for near boiler piping.Couple that up with a T drill and it's awesome!
  • Dale
    Dale Member Posts: 1,317
    Flue
    Remember the code does not allow vent connector to run through divider walls.
