primary circ control
jersey devil
Member Posts: 7
Am I correct to wire the primary circ to run only on a call from a secondary circ?I have 2 bbrad zones a in dirhw zone and a future radiant zone.Each with own circ and a honeywell 675 od reset on boiler with dhw priority and boiler protection. but no one explains the primary circ run cycle or control seq.installed many boilers this is first pri sec and i thought id try my house first. any tech advice is appreciated.
try this
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
