steam drip
Bud Heisser
Member Posts: 1
Has anyone ever heard of a "drip pan elbow"?
Its on top of a boiler, on the outlet side of the relief valve. 1" line.
Drip Pan Elbow or DPE
is a device at the outlet of a steam relief valve. It consists of an upward nozzle which inserts itself into a larger vent pipe conducted to atmosphere. The "drip pan" is just that, below and larger than the main vent opening. The purpose is two-fold; 1) to catch drips from discharge or rain that would build up on top of the relief valve seat, and 2) to provide a "disconnect" or decoupling from the vent pipe to the relief valve. This prevents vent line stresses from affecting the valve itself.
Spence Regulator/Spence Engineering carries them, or markets them as made by Lonergan.
http://www.spenceengineering.com/Handbook/index2.htm
Drip Pan Elbows
Manufacturers and their figure numbers
Kunkle 299
Lonergan DPE
Consolidated 1665 1666 1667
Crosby EFS
Keckley 299
* Features
* Sizes 3/4" - 10"
* Cast Iron and cast steel DPE / 299
* Flanged and screwed connections
Hope this helps!0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
