Gravity conversion
Jamie_6
Member Posts: 710
Went out on a boiler estimate today for a small efficiency above a garage. The current boiler is an old oil fired American Standard gravity system, which was converted from steam many moons ago! The system is located in the garage beneath the apartment and has exposed mains. I am afraid if I convert it to forced hot-water that the pipes will freeze.
Any Suggestions?
Jamie
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=289&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Any Suggestions?
Jamie
Why Not
change it back to steam?
Tell us more- was this once an extension of a steam system in the main house?
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"All Steamed Up, Inc.
Consulting0 -
Gravity won't freeze but forced circulation will cause it to freeze? Why? (Aren't you going to do constant circulation?)0 -
they would like an oil fired boiler w/ a coil in it!
conversion
You could always use non-toxic anti-freeze in a hydronic system.0 -
Why not...
Pipe the boiler P/s with a system circ running continuously and then inject into the system with the boiler pump (equipped with a Flo control)on a call for heat?
Boilerpro0 -
Jamie
TRy constant circ. with TRV's on the radiators. Your customer will love it and will be shocked at the comfort level. Get some reset in thier either system or boiler and you've got a sweet system.
Scott
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
