thread sealant
dave_18
Member Posts: 9
What type of pipe thread sealant do you guys recommend when joining 2 threaded pipes together? This is for a hot water CI radiator system. Teflon tape? White teflon paste? I've used some yellow colored paste in previous applications that someone recommended to me but these joints have all developed very slow drips after about 4 months of service.
Pipe dope
Dave,
I have never had a problem with Rectorseal Number 5. I hear good things about Megalock as well, but I have never tried it. I usually combine the pipe dope with 3 turns of teflon on the bottom 3 threads....no leakers to date.
Bill H.0 -
Me too.....
....if the joint's "quality" (nasty looking threads, etc.)is at all suspect, a few wraps of teflon tape, then Megalock sealant. Have had no problems. The Megalock is what the local wholesaler stocks, so that's what we've been using. It seems to work very well.
Starch0 -
I wouldn't have believed it but.......
YES!
What a concept! Any good quality pipe dope laid over a little teflon tape and, voila! No leaks to date!
Try to wrap the tape the "right way", though........0 -
megaloc
megalock, teflon never had a leak yet!!!!!!!!!!!!!! great stuff.0 -
What a concept!!!!!!!!!! why the sarcasm
Why say any more0 -
Anaerobic
thread sealant: Super Dope. I've never seen anything like it; it will seal the most bunged-up threads, even non-tapered threads will seal with this stuff. No need for the Viessmann horsehair for good make-up.
I once installed a Flushometer valve on a 110 psi line; hand tight and no leaks.
http://www.argco.com/cgi-bin/item/1010087.html?id=Cz8anptK
PERMATEX
permatex,permatex, permatex. if thread is ancient or iffy ---a little lampwick then PERMATEX. P.S. DO NOT FORGET TO MAKE UP WITH PROPER SIZE PIPE WRENCHES0 -
You back from school already?
Did Holohan teach you anything?
Industrial Blue Magic
with a coupe wraps of teflon done deal. Out side Permatex aircraft Yah thats it!
OK......What about
The only threads we've had consistent sealing problems with are plastic to metal. Example: We just lashed up (thanks Weezbo) a pool heating circuit to a stainless steel H/X, female threads on the H/X with male threads on the 1 1/2" PVC fittings going into the H/X. Turned everything on, no leaks. A week later the PVC threads are dripping at a very steady rate. My guy used 3-4 wraps of teflon with a smear of Whitlams over top of that. Went back yesterday, cut the fittings out and redid with Leak Lock. We'll see what happens.
What do you guys use for plastic to metal threads? Anything different than metal to metal?0 -
I had the same problem years ago and took it to my
Dad. His solution: never screw metal into a plastic female adapter. Do the opposite. Screw the plastic male adapter into metal female threads even if you have to use a coupling. I have not had leaks since that time with metal to plastic transitions.0 -
this is one of my favorites:)
this is what i say....It is designed to leak, somewhere:) so with that in mind i go this rout take a union red brass thread a nipple into it thenput somehand tightenergy into the equasion .(i prefer blue goo used in the auto motive trade if i have a day, if not, i will go with teflon and blue magic ) tighten it with a wrench so it then seems snug.) leave the uninon a little loose so it will leak a drop or two.once i pressure it up i take two wrenches and snug it till it quits leaking. that definitely works for me. gone are the days of a leak you didnt plan andthe place it will want to leak is the union
a twist of two wrenches done deal:) 0 -
Plastic Male Adapters
Are notorious for snapping off at the base of the threads--particularly underground...0 -
Try......
lots of teflon tape lubricated with liquid dishwashing soap up to 10 or 12 wraps on 3" and larger fittings usually 5 to 8 up to 2".Sounds ridiculous works like a charm.
John0 -
Oh Yeah!
I used this when I did a stint as a sprinklerfitter. Claims to "harden to pipe burst strength". pressure test everything in that trade to 200PSI. always holds. But bring the BIG wrench if you need to undo. it gets HARD!0 -
Plastic to metal seals, hot water
Genoa the cpvc maker has fittings for this application. If you try to go with a straight adapter on a hot water application it will leak because of the thermal expansion differences. The adapter has flat gaskets that take the strain.0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 389 Solar
