Heat Transfer Products, Inc & the Munchkin Heater
beeper
beeper Member Posts: 32
Heat Transfer Products, Inc. has always been a company that has supported our products and we will continue to support all brands we sell. We strive to provide the highest quality appliance available on the market today from the SuperStor Ultra Indirect hot water heater to the Munchkin High Efficiency Heater.
We would like to address the issues related to the EBM combustion fans. We choose the EBM fan due to their representation in providing the highest quality and reliability combustion fan in Europe and the United States. EBM fans are used on almost every wall-hung boiler in Europe. EBM has worked with Heat Transfer Products to address the issues related to some of the fan failures. The main problem we have had with the fans has been related to the shaft connection to the impeller wheel on the 199M heaters. We have addressed this issue by changing the design of the 199M to incorporate a metal insert, which reinforces the connection point. Extensive testing was done and the new design has been implemented on all 199M heaters. We have also implemented a continuous fan-testing program, which tests fans we purchase on a continuing basis at our factory. This test cycles, 15 fans for 100,000 cycles, which will than be analyzed to address any issue that might interfere with the fans overall quality. EBM has also agreed to set up a similar test.
Heat Transfer Products, Inc. is changing the warranty policy to extend a three-year warranty on all combustion fans installed in the Munchkin Heaters. This three-year warranty will also be extended to existing Munchkin Heaters. The replacement cost can be addressed through our warranty department. Heat Transfer Products, Inc. is focused only on the high efficiency market and will continue to support the trade on any and all products we manufacture. If anyone has any questions or more importantly any issues that you would like to discuss, our technical support team will help to address your question.
Thanks for your continued support!
Respectfully
Jeffrey M. Cook,
Technical Support Manager, Sales Representative
