Need a source for
I need a source for stainless steel crimp-on disconnect terminals. 0.25in, preferrably both straight and flag.
Mark
  • fishface
    fishface Member Posts: 10
    You might try Sta-Kon terminals. They are made by a company called Thomas&Betts. I know they make terminals plated with gold, silver, and nickel. They might make something that would suit your needs. The website is www.tnb.com . Hope this helps, Good Luck!
  • S Ebels
    S Ebels Member Posts: 2,322
    What's
    What's your application? Corrosion problems? You might want to look for something other than stainless due to the fact it is not as conductive as typical connector materials. Something in silver or gold plate will be your best bet.
  • Mark J Strawcutter
    Mark J Strawcutter Member Posts: 625
    Yes, corrosion concern
    Primary application is for A/C condensor connecting primary power to contactor. I seem to remember someone (not here) recommending stainless. Can't remember who it was :-( only that they ran about $3 each (ouch!) but saved him problems down the line.
    T&B Sta-Kon is what my supplier handles, but they don't make stainless.
    Thanks for the suggestion, I'll check into silver or gold plating.
    Mark
  • Firedragon_4
    Firedragon_4 Member Posts: 1,434
    Another trick is to
    cover the connections with shrink tubing. Goes on easy with a heat gun and comes off with a knife.
  • Weezbo
    Weezbo Member Posts: 6,231
    i am suprised!
    many of you live near the oceans ,the connectors used in boating and marine electrical would seem the best bang for the buck!
  • clammy
    clammy Member Posts: 3,228
    die electric grease
    Have you tryed a die electrive grease at your electrical connection have found it very usefully in corrisive eviorments help to cut down in corrisive situtions good luck peace
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
