New main vents leaking water?
GW
Member Posts: 4,693
Hi guys,
We did a steam swap a few weeks ago. I noticed that one of the two main vents (#77) are coated with a rusty redidue, and water stains on the boiler right below it. The pressure is set at the minimum, and we're a good 12" from the 90 drop to the boiler return, up on a 3/4" x 6" nip/coup. I've never seen this, can the vent be bad?
Gary
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=171&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"</A>
Gary
The vent may be shot now
you don't have dry enough steam, gary and the returns could be clogged. I don't put new main vents in until I clean the hell outta the boiler and the returns OR you will beat the crap outta even the best of vents the Gorton. Mad Dog
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
