Auto dial device for no heat.
Tom K.
Member Posts: 3
Can anyone tell me where to get a automatic phone dialing device that senses a low temp no heat problem? If so how where can I get one and appr how much? Thanks tom
Auto dial
Had a customer who had the burglar alarm company add a low temp stat to her alarm system so that when the house got below say 50 degrees it would trigger ??Best Wishes J.Lockard0 -
Freeze Alarm
Try
http://www.controlproductsinc.com/
A very simple device that dials a pre-programed number if the room temperature falls below 45F. Several models available, I have the cheapest one.
I got mine @ Home Depot.
dbx0 -
Dialer
The Sensaphone has four sensing inputs (one for temperature), plus power sensing, plus a listening microphone for under $400. You can call it, or it can call you on trouble. While a bit more money, more features.
Just Google "sensaphone"0 -
Radio Shack has em too....
Freeze Alarm by
Control Products Inc out of Minneapolis, MN. Check out their FA-DX model (attached brochure).
Call Chuck Guerin at 952-448-2217.0 -
dialer
I have one that calls my pager and tells me: it's location, high or low temp.,no power to equip.,no gas press.,no water press.,no power to sump pump,high water in the sump pit and CO alarm. Works great for apartment buildings. Their maint. guy gets the page and calls me, the gas co. or water co.
It has 8 inputs and can monitor any condition with the proper sensor.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
