Copper vs steel for cast iron rads
Scott Lind_2
Member Posts: 2
Thank you Mike for sharing your opinion. I'm leaning towards black steel.
Copper vs. steel for cast iron rads
We will be re-installing a bunch of cast iron radiators in a home that has been completely gutted. One guy says pipe with copper and use dielectric fittings. The other wants to use steel.
What are the advantages/disadvantages of the two materials? I'm looking for the longest life installation here, not lowest cost.
Thanks for any opinions!0 -
See the following thread may give you some insight
http://forums.invision.net/Thread.cfm?CFApp=2&Thread_ID=13430&mc=80 -
Hard to beat black steel regarding durability in a closed hydronic system. While it might not last centuries like the older black iron I think you can consider it a "permanent" material.
Copper has a pretty good track record as well I believe but since it hasn't been used for as long (commonly at least) it may or may not have similar life expentancy. At least oxygen diffusion isn't an issue with either
One disadvantage I could see with using copper in standing iron systems is mechanical damage--particularly if copper is run all the way to the radiators. While they're not removed often and don't tend to want to move copper is quite soft and you'd certainly have to be careful when installing/removing those massive things... As long as the angle unions and valves are brass (yellow brass in particular?) I don't think there would be a problem with dielectric corrosion when using copper.0 -
is this in a ....
steam or hot water system?
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
