grundfoss flowcheck chatter
steve_38
Member Posts: 74
when a flow check valve chatters, it's because of
air in the system, but it doesn't seem like you have
a problem with air, i believe your problem is in the flow
check valve. without air in the system a bad flow valve could still make chatter sounds useually when the circ is on. i have replaced many flow valves for that reason. plus on a too much heat call the weight in the flow check is useually hung up.
grundfoss chatter
i have a system with a few grundfos 15-58fc's with the built in outlet check - one of which chatters - at least it sounds like thats it, it could be air - since it's the highest pump, hoewever - the system is has a spirovent on the primary and the secondary, - dont think it's cavitation with temp of 175 a static pressure of 20 - it seem to do it a lot less at colder temps, anyone?0 -
geeze
that would be a new one on me. the only pump we have had any noise out of was a few taco IFC's.
Never had a problem with the Grundfos.
Please keep us posted though!
Mark H
i know,
when i get a chance i will swap it with an adjacent pump - and will advise0 -
Check to check
for partial blockage. A solder ball, strip of teflon tape, wood chip, etc, may be hampering the flow or operation.
I haven't had a problem, with chatter or noise, even when used in a variable speed assignment
hot rod
you can take the pump out and change the check vakve. this is not a hard thig to do. i would try that first.
Grundfos flo ck chatter
What speed are you running the pump on ? Is the flow too much for the zone ? May want to look at it, the velocity can also cause the flo ck to chatter."Call a Pro~in the end you will save some dough "0 -
well i finally went back and..
took off the pump, took out the checkvalve, shook it out good, cleaned up the check valve, put it all back together and now it's quiet - go figure0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
