weekend projects
carl_6
Member Posts: 4
A weekend project for you guys with leftover parts..
Everybody is familiar with the wood subfloor notched for pex tube. Ever thought about putting some under your mattress? Use a night setback stat to get it warmed up an hour before bedtime, or a timer if you've got it balanced exactly right. Don't forget flex connectors between the mattress and manifold.
Most people spend 1/3 of their time there, so you might as well be comfortable. You can create multiple zones, if somebody wants their side warmer. Space the tubes closer at the far end if your feet get cold.
Ask hot rod
hot rod I'am sure had experimented with your idea ? I bet just about every square inch of his home has pex running through it by now0 -
radiant bed
Someone posted pictures here, about a year ago, of a bed frame with radiant tubing installed. Someone commented that their wife made a fairly good radiant bedwarmer. I recall thinking that, since my wife is more of a hot-air bed warmer, whether I could convert her or install a more recent radiant model.0 -
I think its safe
to say, Aidan, that your wife does not frequent the wall ;-)
Chuck
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0 -
No,
not often. How did you guess?;-)0 -
radiant bed
75 degrees in heating mode- 66 degrees in cooling mode, with nite setbackTo learn more about this professional, click here to visit their ad in Find A Contractor.0 -
WOW and i thought i took my work to sleep with me. i am impressed bro.0 -
Air Alternatives
Aiden, have you considered adding some heat recovery ventilation with perhaps a carbon scrubber for bedside relief? Works well with a radiant system...
Nice job, Bob. Looks like you guys are way ahead of me.
However, if my wife makes me re-upholster my favorite recliner, there might be a couple feet of tubing added while it's apart.
And maybe the couch too.0 -
Fat woman
Warmth in the winter
Shade in the summer
Ayha
thanks Carl
you hit the nail on the head. people laugh, even radiant guys snicker, when i tell them about it, but like you said you spend 1/3 of your life there. i think it makes more sense to heat a bed than any other application, including bathrooms. with nite setback and only the beds being heated at nite- think of the fuel savings. my 2nd floor gets down to about 50 degrees. on the hot summer nites the cool water draws heat away from your body, it's a beautiful thing. bobTo learn more about this professional, click here to visit their ad in Find A Contractor.0 -
OK If that bed doesn't sweat....
how about some pics of the piping arrangement, I remember you telling us of how you get the cooling done!!
Outstanding !!
Murph'0 -
it dosen't sweat
at all. i have used it for 2 cooling seasons so far. the pex is sandwiched between insulation and the mattress. it's a simple piping arrangement- primary secondary piping with a thermostat, relay, circ. pump, and a thermostatic mixing valve set to 120 degrees. bobTo learn more about this professional, click here to visit their ad in Find A Contractor.0 -
You are a pisser ...
good idea Mad Dog
That's the one!
That's the one I remember. A brilliant idea. You can get electric underblankets, but they've got a bad reputation as a fire hazard. My mother had one, but never took it out of the box. Going to sleep under a 230V wrapping doesn't appeal, tukeys and bacofoil come to mind.
I found out, a long time back, that if you sleep while you're cold, you wake up tired. The body is doing vigorous shivering to keep warm and the mind sleeps uneasily. How much more restful would a night's sleep be if you could control the environmental conditions (T, Rh) at the ideal level, like in those isolation tanks? The conditioned space would only be around 25 or 30 cu. ft.. The psychologists must have researched this one.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
