cv ratings
smoore
Member Posts: 28
does the larger the cv rating mean the valve is more restictive or less? can anyone explain these to me.
less
the higher the Cv rating the less restrictive the vavle is. Cv is defined as the number of gallons of water that can flow through the valve with a 1 psi pressure drop. or Cv = # gpm divided by the square root of delta p in psi.
Hope it helps0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
