And you thought you had a bad day....
Floyd_5
Member Posts: 418
were setting the frist concrete beam... not sure if the ground gave way or if it was operator error....the crane was setup in a creek bed.....
between the bushes you can see the wheels of a flat bed that the crane flipped on....out of sight and laying in the creek is the beam, in a bunch of pieces.
I think the sign says it all.
The sign says it all!!0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
