Stair climbing hand truck
Bill_18
Member Posts: 13
Gentlemen, Any pros or cons on electric stair climbing hand trucks? What brands do you recomend? I just finished a heavy boiler replacement, I thought those stairs would never end on the way up. There is a lot of grunt work in this business isn't there.
stair climbers
there was a post on this awhile ago, but I have an Electro-truck unit that is a great unit. I bought this one because of the wheel set up (big wheels). It's truly an all terrain unit and is at much at home on the grass as concrete. It's heavy, but does heavy work with relative ease. Heavies load to date was a six section Peerless up two flights on one battery charge....(taking it out in one piece)
The aluminum model is lighter weight but has a lighter payload. Whenever using one of these, make sure the stairs can handle the weight. A few 2x4s and long sheetrock screws can make any set of stair strong enough, in minutes.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
