Heating a basement
Harry
Member Posts: 3
Have 1 pipe steam system and need to heat basement. Not sure which is better. I can tap into main for 3 radiators, use F & T traps and a condensate tank to feed water back to the boiler or run a hot water loop. The hot water loop would be easier. Does anyone know where I can find out more about a hot water loop on a steam system?
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
