above slab radiant?
RADSTEVE_2
Member Posts: 9
I have a customer building a weekend art studio. They are putting down a slab but want the radiant to be more responsive because of the part time use thus they are considering above slab radiant. The floor covering will be kiln-dried pine boards. Any thoughts about this situation including type of insulation?
above slab radiant
Put it in the walls......
Above the floor radiant.
Check out the Roth foam panels. They would be excellant for this application. Low mass and low temperature. Panel thickness is 3/4". Constant circulation would be the best way to control temperature in the room and provide even temperatures. Roth manifold shunts might be he ticket. Be sure you do your research on the pine flooring to make sure your not going to have any problems with shrinking or warping. Check out Radiant Panel Association for some direction on floors and Roth Industries web sites.
www.roth-usa.com & www.rpa-info.com0 -
Try the RAUPANEL System by REHAU. I used in a basement and worked well. Fast response and low temp water, will not hurt the wood floor. Check it out at rehau-na.com or call the local rep.0 -
This months PM mag
has an article on various radiant subfloors. Click the link here, unfortunatly the pictures don't appear? See if you can find a copy of the mag.
hot rod
http://www.pmmag.com/CDA/ArticleInformation/coverstory/BNPCoverStoryItem/0,2372,101161,00.htmlBob "hot rod" Rohr
Living the hydronic dream0
- 120.2K All Categories
- 83.6K THE MAIN WALL
- 2.8K A-C, Heat Pumps & Refrigeration
- 52 Biomass
- 414 Carbon Monoxide Awareness
- 30 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.6K Gas Heating
- 152 Indoor-Air Quality
- 2.9K Oil Heating
- 49 Pipe Deterioration
- 736 Plumbing
- 5.2K Radiant Heating
- 357 Solar
- 13.8K Strictly Steam
- 3K Thermostats and Controls
- 50 Water Quality
- 36 Industry Classes
- 70 Job Opportunities
- 14 Recall Announcements
