NECA boiler
hombre de oleo
Member Posts: 17
I have a customer with a 1989 NECA boiler.It's an M-4 midy. All I can find on it is that it is made by Necchi and Campiglio. I need gaskets, and clean out covers which are located on the top of the boiler. Any help with reps or distributors would be very much appreciated. Greg
Neca Boiler
You should call QHT,Inc. @ 1-800-501-7697, Portsmouth, NH.
Jim Quincy or Keith should be able to assist you.
Jed0 -
NECA
Jed, Thanks for the lead. I will call Sat. AM. If not, bright and early Monday.0 -
Not open Sat.
Oilman, Is that right? I'm not good at Spanish. Just a guess. Monday about 8. Jim has a bit of a drive to get in.
Maybe 8:30.
Jed0 -
oilman
Correct. Just a weak attempt at levity. Thanks again. I have this boiler,"midy M-4" cold start, in a damp crawlspace, and you can probably guess the rest. My customer bought the house,not too long ago, and brought me in to "buff it up",after many years of abuse and neglect.I need gaskets, and the plates and tension screws that cover the top clean-outs.I looked everywhere but could not find any rep or wholesaler.I was hoping to find help here.0
- 110 Chimneys & Flues
- 106 Geothermal
- 978 Plumbing
- 387 Solar
