Danfoss ZCP tool
hot_rod
Member Posts: 25,494
slight modifications I installed hex key ends into these screw driver handles. The allen end fits the Danfoss actuator heads, and the straight blade screw drivers fits the terminal strip in the ZCP panels.
Only the names need to be changed to protect the tool hacker :)
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
hot rod
Tool Time for ZCP's....
Hot Rod...
Less toil with these tools...
You're inspirational!
RB0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 995 Plumbing
- 391 Solar
- 55 Water Quality
