the Humphrey valve
Unknown
Member
http://www.fortunecity.com/greenfield/bp/16/hump.htm
the Humphrey Valve
This is not a joke!
I'm hoping that some one has used, seen or been bit by one of these and can explain it to me.
It is an integrated componant of an air pump that is reported to be able to non-electriclly drive a forced hot water heating system.......
Ok, let's hear from you, soon0 -
I've looked at
the drawings you sent until I got dizzy.Retired and loving it.0 -
Dizzyness
can usually be cured with a bowel of cream of celery soup,
this cure, however, will not help much with the Humphrey
valve.......
Is there a knowen method for moving fluid thru a radiant pannel system non-electriclly?
The suggestions from the Hoover Pump Works include the recomendation that the water temp be set at 180 deg. F....
Bubba, we got bells, whistles and red flags all over the place with this one. The only part that I have recognized
is the Burnham boiler with a milli-volt gas valve.
So have some soup, and give me a shout, I'm here in the shop making a gas tank for a 20hp, 1902 Lauson Gas Engine.
The fun never stops.cp0 -
It's
Amish, though, right?Retired and loving it.0 -
Well,
yes, does this make a differance?0 -
No,
it just looks like something they would use.Retired and loving it.0 -
They
also use horses....but then, who ever heard of a horse that
worked on milli-volts....0 -
They work on
horsepower!Retired and loving it.0 -
Ok, ok,
I know some else on the planet must have locked horns with one of these rascals eather by design or accedent. I will not be deterded! Please expain this to me or I will continue to post non-sense. We don't want that, now do we......0 -
Go to Google.com
and search Humphrey valve. Lots of good stuff pops up.Retired and loving it.0 -
Dan It's Hay!
I thought that horses ran on HAY? Ever rebuild a condensate return pump for a horse? Handle at the impeller shaft and a big single impeller blade at the end. One people power. Mmmmm, and the smell.! Nuff said
Art0 -
Art, you've got something there!!!
This thing will run on hay! Wood, charcoal, even tar! This pump is a real eye opener.
The gas holding tank works just like the one I used to work with; that said GAS HEAT all the way around the top of the holder and lived in the south end of Concord, NH.
Noel0
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 389 Solar
