SMALL VARIBLE SPEED DRIVE
RonS
Member Posts: 10
I am trying to find a varible speed drive for a small snow melt job that is controlled by tempture to run a primary pump to a heat exchanger. the pump is a taco 0010 pump and it has a the full load amps is 1.2 and 115 vac HELP thanks
Do I understand ?
You want to automatically control of the speed of the pump by temperture ?0 -
yes I want to controll the pump on the primary side of the heat exchanger by the supply temp on the secondary side0 -
variable drive
> thanks
variable drive
Just talked to my rep and he showed me a heat timer set point control with a pressure or temperature resistor to control the variable speed B&G pump. Looks pretty simple. Appx. $250.000 -
Look at the major
"Controls" manufactures. I.e. Tekmat, B&G, Honeywell, Taco, Infinity Labs, Goopd luck! bigugh0 -
Johnson Contols makes...
an electronic speed control that I have used as a varaible speed control for small pumps. It requires a 0-10 VDC input, so you will have to have a temperature control that outputs 0-10 VDC, something like the Johnson A350 series. A company called Viconics also has neat thermostats with the option of remote sensors that will work. The Johnson speed control is a model S66AA-1C.0
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
