taco vortex
Bruce
Member Posts: 27
Is the taco vortex an air scope or more like a spirovent.I guess is what a want to know is does the vortex need this 18" straight run before it can work properly.
Thanks Bruce
Thanks Bruce
According to Taco
"no minimum length of pipe required after bend or elbow"
and they say no more than 10 ft/sec flow rate. Hope this answers your question.0 -
Thanks Eric
What does that equal to in a 3/4 copper pipe @ 2-3 gpm
Bruce0 -
I may be wrong but
I think 10 ft/sec using 3/4" pipe comes out to 15gpm, but you might want to wait for someone else to post a reply.0 -
If i only run 2 ft/sec.
will the vortech still work Bruce0 -
Yes, It will work
Yes, It will work. The max ft/sec is based on the ASHRAE recomendations for velocity noise not the effect on air separation.
- Mark Chaffee
Taco,Inc.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
