heating a small area
Roger G
Member Posts: 1
I was wondering if anyone could help me. I was hoping to use a small electic hot water heater, a circulator pump, an in-line thermostat(120 volt) and baseboard to heat a small part of my basement. The area is no where near the boiler I have now and I was wondering if anyone has tried this before. If so what else would I need(expansion tank,
auto feed,......)
Thanks in advance
Roger
P.S. The area is a playroom for the kids and I can shut the system off when its not in use.
auto feed,......)
Thanks in advance
Roger
Why not just use electric baseboard? Operating costs per KWH would be virtually the same, and a lot less parts involved with running romex. Also each electric baseboard could have a thermostat for zoneing.
Any way to install radiant floors? Bt far a much nicer way to heat over a cold concrete slab. Zone it off the exisiting boiler??
hot rod
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"Bob "hot rod" Rohr
DV wall furnace
Gas, lp or nat'l, COOL TO THE TOUCH, 84% eff, vent exts for basement install, built-in t'stat, fully modulating gas valve and blower. www.rinnai.us.com. How big a space. Probalby the rhfe-263, but maybe the 431. Extreme reliablity0 -
turbonic space heaters( chill chaser)...
you can tie this in to your exsiting loop with mono-flow tees and when the up stairs calls it will heat up and the built in fan relay turns on the fan and blows like a little warm air furnace. or run it off a t-stat so you wont over heat the room - t-stst will let the blower come on only when the room needs heat if not the water just passes thru hope this helps ... David Sutton0 -
can you run 3/8\" pex...
....off the closest pipe down into the basement...0
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 389 Solar
