heating a small area
Roger G
Roger G Member Posts: 1
I was wondering if anyone could help me. I was hoping to use a small electic hot water heater, a circulator pump, an in-line thermostat(120 volt) and baseboard to heat a small part of my basement. The area is no where near the boiler I have now and I was wondering if anyone has tried this before. If so what else would I need(expansion tank,
auto feed,......)
Thanks in advance
Roger
P.S. The area is a playroom for the kids and I can shut the system off when its not in use.
    hot_rod Member Posts: 25,440
    Why not just use electric baseboard? Operating costs per KWH would be virtually the same, and a lot less parts involved with running romex. Also each electric baseboard could have a thermostat for zoneing.
    Any way to install radiant floors? Bt far a much nicer way to heat over a cold concrete slab. Zone it off the exisiting boiler??
    hot rod
  • Jack_23
    Jack_23 Member Posts: 153
    DV wall furnace
    Gas, lp or nat'l, COOL TO THE TOUCH, 84% eff, vent exts for basement install, built-in t'stat, fully modulating gas valve and blower. www.rinnai.us.com. How big a space. Probalby the rhfe-263, but maybe the 431. Extreme reliablity
  • David Sutton
    David Sutton Member Posts: 82
    turbonic space heaters( chill chaser)...
    you can tie this in to your exsiting loop with mono-flow tees and when the up stairs calls it will heat up and the built in fan relay turns on the fan and blows like a little warm air furnace. or run it off a t-stat so you wont over heat the room - t-stst will let the blower come on only when the room needs heat if not the water just passes thru hope this helps ... David Sutton
  • Dave_4
    Dave_4 Member Posts: 1,404
    can you run 3/8\" pex...
    ....off the closest pipe down into the basement...
