Best control device for Steam Boiler in a commercial building
Wayne_2
Member Posts: 10
Trying to control Firehouse type buildings, what control is best for this. (No thermostats please)
Try
Heat-Timer or tekmar. Both have controls that regulate the steam based on outdoor temperature.Retired and loving it.0 -
Thanks Dan
WHAT ABOUT ESI' AD2000 CONTROLLER?
I've never
heard of that.Retired and loving it.0 -
ESI controller
I didn't mention the ESI controller here because I felt a firehouse would be more uniform in its requirements. It is also occupied most of the time, and can be adjusted if necessary. A heat timer or tekmar should work fine here.
To Dan and others, check out www.esicontrols.com
This steam controller uses outdoor temp for duty settings, but fine tunes by using room sensors. It will run a number of room sensors, averaging them all, and dropping off the high and low. It will also show the room temps over a 24 hr. period for any of the sensors, and can be controlled remotely. A perfect control for multi-unit apartment buildings.
Chris L0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 391 Solar
- 55 Water Quality
