What happens to pex when
Steve Ebels
Member Posts: 904
What happens to pex when it's buried in concrete and there is no place for it to go?? I've heard many discussions on this topic but never any definitive answers. We all know that the stuff grows at an alarming rate when hit with hot water so what happens to it when it goes from 50-90 degrees in a slab? My theory is that it has to expand and the only direction it can grow is inward, effectively making the ID of the tube smaller.
Does anyone know for sure??
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=175&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
time to be the molecule
se,
If this is true and your panel is around 250ft how much can it really effect the flow? Could it be enough to even conceder?
al0 -
That is what I've been told by a couple of different tubing manufactureres.
I was also told that their software takes this into account when it calculates FtH2O and GPM.
Mark H
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
