opus by burnham
anyone have any experience with the opus.Looking for any first hand knowledge.
  • eleft_4
    eleft_4 Member Posts: 509
    opus
    Ralph,
    Copy this & paste in your address line or click search and type opus
    (http://forums.invision.net/Index.cfm?CFApp=2&Message_ID=4166)
    al
  • keith
    keith Member Posts: 224
    Opus
    looks like a nice product. I am a little confused. Is it a direct vent oil fired or do you need a power venter for a non chimney application?
  • GAverill
    GAverill Member Posts: 10
    opus
    We are in the process of having six 250mbh gas units installed in a nursing home in our territory, replacing relatively new competitive products that have failed in 4 years. With 2 units in so far, everyone is impressed to date.
    The key I have seen to these being applied to any system is a 140F maximum water temperature, which will stop some from being installed in existing applications.
  • Opus Oil Boilers
    Ralph,
    The demand for Opus products is increasing more each day as contractors install their first one. The temperature limitation of 140°F is only limited to the G-1 gas models. The Oil-fired models operate with normal system water temperatures like any other boiler. The big differences are the built-in primary-secondary variable speed injection system that the O-1 oil models have. This along with large water contents increases the AFUE efficiency almost to 90%. All Opus products come with an easy to program Energy Management Control Center temperature reset system and six zone relay pre-wired. Here are some pictures of an oil install in the Berkshires in a 150 year old farm house. This particular one is equipped with a Riello Burner. Beckett with a cover is the standard and Riello or Carlin are optional. Hope this helps.
    Glenn Stanton
    Burnham Corp.
  • Does Opus Oil have
    Energy Star Rating?
    I would like some technical literature on the Opus gas unit. Where is it available?
  • Sven
    Sven Member Posts: 34
    Opus literature is
    on the Opus web site, along with spec sheets, and ratings:
    They do offer a gas and an oil version:
    http://www.aboutopus.com/
  • All Opus products
    proudly wear the Energy Star label Tim! The Opus G-1 Heat Source approaches an AFUE efficiency of 99.7% and is fully condensing. The Opus Oil-Fired boiler approaches an AFUE effciciency of 90% without condensing. As I stated in a reply to your e-mail, the info is in the mail. Thanks.
    Glenn
  • Thanks Glenn
    Some oil guys were asking me about Energy Star Oil Boilers and I wanted to make sure Opus was listed. Thanks for material.
