Peerlees boiler sections.
Lawrie bruton_2
Member Posts: 3
I need 1 left hand end section and 3 intermediate sections
10 push nipples and the gasket material between the sections.
Hope some one can be of help
Lawrie
Lawrie
Some more info
Peerless makes a wide variety of boilers . Do you have the model number of the boiler ?0 -
Peerless sections
The boiler is a model 170-17-S
Lawrie0 -
I am unfamiliar with that model
It must be a big boiler if you want to just replace some sections , rather than the whole block ? Or are you building a new boiler with sections you have left over ?0 -
Peerless Parts
Check out www.peerless-heater.com this is there home site w/rep. links hope this helps0 -
Peerless boiler sections
we are re-buiding the boiler in a school it will remain the same size
we have checked with peerlees and the parts are not available
Lawrie0 -
Peerless parts
Lawrie, check that link I posted and start calling some reps. you will find someone,even if they don't have them that can lead you to them somewhere.0 -
Lawrie
I am checking our inventory this A:M:. We have some peerless sections from an inventory buy out. I am not sure what series they are but will get back to you sometime today.0 -
Peerless Parts
Try H.C. Oswald, 120 E. 124th St. New York, N.Y. 10035
Phone 212-722-7000 Fax 212-860-2843
I have been able to get sections and parts for various obsolete boilers from them. They don't have a web page as far as I know. Good Luck.0 -
sorry
I did not get you that section info. Were you able to track down what you need?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
