Tankless Scale Removal
RickDelta
RickDelta Member Posts: 621
edited November 2024 in Domestic Hot Water
Hello HeatingHelp.com community! : )
In a commercial hot water (potable) tankless environment (high volume), the need can be as short as every three months to vinegar wash out the system. Scale build up servicing is mandatory for heat exchanger warranty coverage.
It is my contention, that the use of a cold water inlet pre-treatment with a TAC (Template Assisted Crystallization) filter would then negate the required vinegar flush entirely and preserve the covered manufactures warranty.
……. thoughts on this?
  • Larry Weingarten
    Larry Weingarten Member Posts: 3,810
    Hi, I found this article: https://waterfilterguru.com/what-is-template-assisted-crystallization/#:~:text=Learn%20what%20%EE%80%80TAC%EE%80%81%20is, They suggest TAC can reduce scale buildup by 90%, so you would still need periodically to descale the heater. If your heater has any way (maybe with a boroscope) to have a look inside of the heat exchanger, it would be useful to really know how well the TAC unit is working. Seems that as long as you can demonstrate that the heat exchanger has never been fouled, warranty on the tankless heater should remain in force. 🤓
    Yours, Larry
    RickDelta
  • RickDelta
    @Larry Weingarten
    Thanks Larry!
    My thoughts are that if it stops the scale minerals from attaching in the first place "AND" ……… removes any scale that had already established itself to the heat exchanger , that there should not be any significant scale left. (hence no need for a vinegar wash)
  • RickDelta
    ……… pondering:
    Where you normally connect to the vinegar "flush" ports , a small circulator to act as a TAC "scale scrubber" loop during idle flows 24/7 ? (no vinegar)
    The same loop could "scrub" all heat exchangers, even in a large commercial 24 unit tankless group.
  • Larry Weingarten
    Hi, I'll throw in that salt softened water is good for water heaters in that it slows sediment build-up in tanks, but bad for water heaters in that it increases conductivity of the water, accelerating sacrificial anode consumption. I've seen anodes completely used up, down to a bare wire, in six months with softened water. So, there is a balance to be found.
    Yours, Larry
    ps. I'll add that whatever is done with TAC, it would be really useful to be able to do a visual inspection, so you know what's going on.
    Revenant
  • RickDelta
    @Larry Weingarten
    With the relatively small heat exchanger surface area of a tankless unit ….. I was amazed of just how fast you lose this high efficiency to scale accumulation.
    Its my contention that removing the scale build up, at its earliest formation, before it has a chance to drop its heat transfer efficiency ……….. is to perpetually "scrub" the heat exchanger of the scale minerals during its no-flow idle state.
    I'm installing a new "Quad" tankless group in about three weeks at one of our motels.
    In prima facie …..
    I think I can easily form a closed recirculate loop (aka: keep alive loop) from the cold water TAC filter and the "flush" ports on all four of the tankless units isolated with spring loop checks. Control the scrubber circulator with the tankless own flow detector.
    hot_rod Member Posts: 24,973
    we make these phosphate dosers for residential tankless and combi boilers
    You could probably find or make something similar
    https://www.caleffi.com/en-int/under-boiler-polyphosphate-dispenser-5459-caleffi-545950
    RickDelta
  • RickDelta
    @hot_rod
    Hi Hot rod! : )
    What's the working principal of this unit? (didn't get much from the link)
    Despite the benefits, excessive use of PolyPs in food products can increase potential health concerns. Kidney damage, cardiovascular issues, and weakened bone due to calcium-phosphate imbalance are some of the potential consequences (Calvo & Uribarri, 2013Kemi, Kärkkäinen, & Lamberg-Allardt, 2006).
    This unit "doses" polyphosphate crystals that dissolve and mix into the water??
    There are pros and cons to all the various treatments for water. Ion exchange softening, TAC, phosphates, RO,
    We looked at bringing these phosphate dosers to the US market, but the capacity seems far too small for typical US water users.
    Tap water is very expensive in Europe, they tend to use much less.
    Research and find the water treatment method(s) that you are comfortable with.
    RickDelta
