Hydrostat Hi limit issue
You are correct, the vibration is moving the knob. Another reason I prefer Honeywell L7224U.
You could try some painter's tape on the knob to the circuit board. Call the supply house where the boiler was purchased and see it they can offer warranty replacement. Most boiler parts are only 1 year warranty, but you may have extended warranty. Doesn't hurt to askEdward F Young. Retired HVAC ContractorSpecialized in Residential Oil Burner and Hydronics0 -
Without hijacking the OP's thread, ED, what differences make the Resideo 7224U better than the Hydrostat 3250+?EdTheHeaterMan said:You are correct, the vibration is moving the knob. Another reason I prefer Honeywell L7224U.
https://www.supplyhouse.com/Resideo-L7224U1002-120-Vac-Oil-Electronic-Aquastat0 -
I've never used ODR with the 3250 Plus, but I'd assume there's a max limit setting to correspond to the design day. Maybe go through the settings again.
And I've got many many 3250 Plus controls out there, and never had one mysteriously self adjust.
Maybe a huge delayed ignition could jolt it but...2 -
I did install the ODR sensor, but ODR doesn't work well for my situation, so I have it disabled.HVACNUT said:I've never used ODR with the 3250 Plus, but I'd assume there's a max limit setting to correspond to the design day. Maybe go through the settings again.
I do like and use the WWSD function.0 -
The Honeywell limit is set by pressing buttons to a particular temperature that is displayed by a three digit display and once selected you save that setting. There is no dial to turn. My first experience with the Hydrostat devices was that the potentiometer dials were inexpensive junk that is soldered to a low cost PC Board. Just did not have the feel of a quality built control.MikeAmann said:
That was just my first impression. I retired soon after those controls became standard OEM control on many boilers. Just a personal preference. That's all.Edward F Young. Retired HVAC ContractorSpecialized in Residential Oil Burner and Hydronics0 -
In have a customer that I installed a boiler for with that control. He called me about 2 years after to tell me there's no heat. On arrival I noticed the control locked out on high temp. I reset it with him watching. He's electronics guy, and is inclined to understand these issues. It has happened a couple of times since, so he said. I like the old clunker electro-mechanical controls better, just 'cuz I'm old too.1
How does it lock out on high limit and need to be reset?Kickstand55 said:In have a customer that I installed a boiler for with that control. He called me about 2 years after to tell me there's no heat. On arrival I noticed the control locked out on high temp. I reset it with him watching. He's electronics guy, and is inclined to understand these issues. It has happened a couple of times since, so he said. I like the old clunker electro-mechanical controls better, just 'cuz I'm old too.
It turns the burner off on high limit, like any aquastat. The circulator runs until the call for heat is satisfied, and the burner comes back on after the temperature drops.
IOW, something else was wrong.
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
