Need to replace my control
Ed Lentz_2
Member Posts: 158
we installed a stadler viega Basic controller many years ago. It has worked fine until this week. It controls my boiler, runs the circ pump for a stadler manifold for 4 loops. and also, manages the mixing valve on the manifold. Do they make a controller that will replace this? Do I need the mixing valve component with newer controllers?
Thanks in advance for any insight
One Pipe System1 -
Ha might be. I found a tekmar 360.0
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
