Smell from NYC Radiator
SRubi
Member Posts: 24
My steam radiator in my 1960s apartment building has been smelling like burning iron. This has been going on for about 3 months now. I cleaned it out and vacuumed the coils but it still gives off a smell. When I asked the super they said there is nothing they can do about it that sometimes it smells like that. I have lived here for 6 years and it has never smelled, I am also the only apartment in a very large building that is having this problem. It smells all the time even when no heat is being given and it smells even more when the heat does turn on especially in the mornings or after a warmer spell. I notice it smells the most by the valve that turns it on and off. Any advice would be great, I am getting really frustrated.
I moved into a building in Tribeca on Harrison St in 2014. It had 300 units and mine was the only one with a problem. There was this occasional mothball smell that no one could find. The building decided to replace the radiators at some point even though I knew that wasn't the issue. Still there. We never found it. We moved out two years later. My bet is that your smell is coming from somewhere else. Can you wrap the radiator in plastic or something to try to isolate it?Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes2 -
@JohnNY Seems like it definitely is coming from the radiator and it smells like iron. It's a studio so it's a bit easier to isolate the smell. But so strange my friends in the sister apartment building have been having a strange moth ball smell occasionally-not from their radiator.0
So, you are sure the smell isn't coming from your neighbor's apartment.
Smelly neighbors aren't that uncommon. Sorry, I have bad taste, I guess. I'm sure you have fine neighbors.
You might try washing it with TSP and rinsing it with clear water, use a spray bottle. It's the only radiator in your apt that's affected? Could a rodent be trapped in it and expired?0 -
@HomerJSmith Thank you. Haha I don't think it's my neighbors. I only have one radiator since it is a studio apartment. If I go up to it the smell is clearly radiating from there. I don't smell it in other rooms where the vents are but the radiator isn't- if that makes sense. I had maintenance come and they cleaned it but still smells not as bad though, maybe it needs a better clean??0
Is this a radiator or a convector element in a cabinet? There is a hole where the steam feed pipe comes into that room. Try stuffing something around that incoming pipe (not plastic) and see if that cuts the smell down.
3PSI gauge0 -
@BobC I’ll definitely look when I get home. The smells seems worse by where the knob to turn it on and off is not so much the coils. It also seems to lessen the longer the heats been on. When it’s off for a few days or early mornings is when it smells it’s worst. It’s gotten less smelly over time but still a smell of iron.0
Do you have a cat or dog?Retired and loving it.0
@DanHolohan no and I’ve been at this place for 6 years. First time smelling anything like this.0
Can you take the cover off and see the heating element? There may be something stuck between the fins.
Do you burn a lot of candles? I'm asking because convectors move anything that's able to move through the air into themselves. Stuff goes into the bottom, where the air is coolest, and then rises upward. If things get stuck in there you can get a smell.Retired and loving it.0 -
@DanHolohan I can take the cover off. I had maintenance in my building do it but I’ll do it myself. Hmm I don’t burn candles often and I dust weekly but maybe from years it’s building up?0
Retired and loving it.1
Also, ask your super if anyone added chemicals to the boiler recently. You have one-pipe steam and the air that's in the pipes and convector vent into your apartment on each cycle. That's normal, but if they added something to the system, say for cleaning the boiler, you may be smelling that.
And some people are more sensitive to odors than others. We've seen that many times here on The Wall. Some tenants smell nothing; but highly sensitive people will.Retired and loving it.1 -
@DanHolohan I am definitely very sensitive to smells so I know even though it’s not as bad as it was two months ago it’s still bothering me. I asked maintenance a few times, they said it’s just dust and they can’t do anything. Thanks so much, this is very helpful!0
Happy to help!Retired and loving it.0
besides the 1 pipe vent,
is there a control valve under the convector?
possible a loose union or packing gland, something leaking?
can you determine the odor from one end or the other?
post a pictureknown to beat dead horses0 -
This is where I smell it the most.0
I reached in there with a rag when on and off and I don't think there is any leaking.0
May we see the other side of the convector? Thanks.Retired and loving it.0
Also, please take a pic of the whole convector with the cover off from your POV when you’re standing in front of it. Thanks.Retired and loving it.0
if it's a steam leak (like an air leak) you may not see feel moisture,SRubi said:I reached in there with a rag when on and off and I don't think there is any leaking.
maybe with a cold mirror, when the boiler is running, you might find condensation,
or a big shiney cold salad spoon,
but we need to see the other end of the convector firstknown to beat dead horses0 -
That side smells like normal heat the other has the more metallic smell coming from it, it is not very strong right now, thankfully, but still there.0
I stand I corrected. You have two-pipe steam, so venting smells are not a concern.Retired and loving it.0
There’s rust below the valve. Coil be some steam leaking on that end.Retired and loving it.0
@DanHolohan Do I need to do anything about the rust or is giving it a good clean probably going to help?0
Just the cleaning. I think that will help.Retired and loving it.0
Thank you so so much! This is very helpful, now to cleaning!0
can we get one more of the smelly end, close up, where the brass valve threads into the silver convector header, and capturing all 5/6 tubes to the convector where they attach to the header,
angle down on the shot, from the control knob areaknown to beat dead horses0 -
I tried, I hope this is ok!0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
