Impossible! Can't Find C.I. Baseboard Assembly Tool
ScoutRider
Member Posts: 22
I have been looking for over a month, and heating season is just days away...... So I am about to abandon my cast iron baseboard, as I simply can't find a source to borrow, rent or buy any assembly clamps. Any ideas before I buy fin tube? Thanks.
There's the tool:
https://www.consumersplumbing.com/site/consumers/productdetail.exc?cmd=630_view_prod&isApp=true&page=1&co_id=630&item_id=95779&prod_id=12312
Here's a rental:
https://www.maumeesupply.com/index.jsp?path=product&part=15836&ds=mfr&process=search&qdx=0&ID=,Burnham.Boilier
Could probably make it with some bar stock or tube stock and some long, large bolts too.0 -
I just bought one off ebay0
It's been a while but I remember starting at a service company and we did a lot of freeze and splits. We used to just use a sh&tty old pair of vice grips set at the right spacing. Never did have an issue.0
I used 3 and one oil on the push nipples and rubber mallets to tap the sections together. Never had a problem after the installs.
JakeSteam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron0 -
Try ocsind.com. Don't know if they ship.0
I was able to borrow one from a supply house in NY. They had lost track of it, but they tracked it down and I was able to borrow it. After having used it, I sure am glad I didn't have to improvise!0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
