Remove Air Vent on Boiler (Pumping Away)
Mudaero
Member Posts: 46
Hey all, hopefully this should be quick. If I am building my system using Dan's Pumping Away method, do I still need the air vent that comes directly off the boiler (Weil McClain HE II)? I was hoping I could just cap that as there will be a Spirovent Micro Bubble separator on the supply line.
With just capping it off, I'd be concerned about a large bubble of air building up behind the internal baffle. Not sure if this would cause problems with boiler performance or longevity.
Mark
Indiana PA0 -
I just wish they didn't put that port so close to the supply port. There is very little room to work with and the air vent is basically touching the the supply pipe. Is there any issues if I put an elbow on the air vent pipe just so I can get some space or does it need to be straight up to provide proper air removal?0
You can put on 2 45 ells to create an offset, that should give you clearance.
I would add the ball valve to be able to change the vent without draining.
This gets the air out of the boiler on initial fill, speeding up the process.
Also would help the other vent.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 879 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
