f-34 code
tom317
Member Posts: 2
how to repair a weil mclain ab-155c with a f-34 code
Manual says low voltage problem Voltage under 100v. Can not have more then one pump wired to boiler. https://www.powerequipmentdirect.com/manuals/e956d44093477453217234b7e3ac4cad.pdf
page 90.0 -
Had f-34 code last year and they replaced a tank and a couple of sensors under the mobile home.
Now, they are saying the f-34 code repair consists of replacing the control board for $.
Only has one pump.0 -
Might want a second opinion!0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
